• 280 views | 2 messages Discussion: LEAP
    Topic: Updating of excel files Subscribe | Previous | Next
  • Claude Davis 6/3/2009
    3155 Views
    There appears to be inconsistency on how linked Excel files are updated.
    After saving updates to the Excel file, AND forcing a refresh of excel links, spurious values appear in some LEAP demand data when recalculating Results. The error message is "Cannot convert excel cell to a value etc..".
    On opening the sheet with the cell indicated in the message, and forcing a refresh, the erroneous links (highlighted in red italics) are updated OK (red italics changed to regular blue text).
    Recalculating again gives a similar error in a different sheet but the same process is repeated.
    Does LEAP handle correctly the updating of multiple sheets in the same file or indeed in multiple files?
  • Claude Davis 6/5/2009
    3150 Views
    Using excel files with a single linked worksheet as opposed to multiple worksheets that are linked) resolves the issue.
