• 360 views | 2 messages Discussion: LEAP
    Topic: how to import base year's value into the model Subscribe | Previous | Next
  • zhang lili 6/21/2009
    2299 Views
    These days I used leap,but found if set 2007 as base year,the table shows the value of 2007 is 0.00. where i can input 2007's value or base year's value into the model?Thanks!
  • Charlie Heaps 6/23/2009
    2296 Views
    Hello there
    Make sure you are editing the Current Accounts scenario. That is the place where you can edit the base year and historical data values.
    You can select Current Accounts from the "Scenario:" selection box - available in the Analysis View.
    PS You can also set the base and end year from the General: Basic Parameters: Years screen.
    I hope this helps,
