• 223 views | 2 messages Discussion: LEAP
    Topic: microhydro power plant Subscribe | Previous | Next
  • Rahmat Al hasibi 7/13/2009
    2406 Views
    dear all,
    in our region, there is microhydor potential for about 450 kwatt. i want to include this power plant in out leap model and this power plant will run in 2010. can anyone give me a solution?
    thank you.
    best regard,
    rahmat
  • Charlie Heaps 7/25/2009
    2385 Views
    Hi Rahmat,
    You would need to add that power plant to your list of processes in an electricity generation module (under the Transformation branches).
    Make sure you specify that the plant initially has zero capacity and then specify a step function for the Exogenous Capacity variable to indicate that the plant becomes available in 2010. Like this:
    Step(2000, 0, 2010, 450)
    You will also need to specify other technical characteristics for the process including availability, efficiency (normally 100% for hydro), merit order, etc.
    > dear all,
    > thank you.
    > best regard,
    > rahmat
