• 436 views | 3 messages Discussion: LEAP
    Topic: stock information Subscribe | Previous | Next
  • saeed alaei 8/3/2009
    2268 Views
    Dear all
    in Leap Training Exercize 5, how i can enter the stock/sale(not stock/sale share)information for the base year(namely 6 million cars & 4 million SUVs)?
    warm regards
    saeed
  • Charlie Heaps 8/3/2009
    2267 Views
    >>In Leap Training Exercize 5, how i can enter the stock/sale(not stock/sale share)information for the base year(namely 6 million cars & 4 million SUVs)?
    Hi there,
    A couple of things that may help with this:
    1. In the General: Basic Parameters: Stocks screen, make sure you have a check mark in the box marked "Top-down sales and stock data"
    2. Second, in the demand tree, make sure you have set up all your lowest level Technology branches in your demand tree using the method "Transport Analysis". NB: Do NOT use "Activity Analysis" You can review these methods by clicking the Properties button for each branch in the tree.
    Your tree should look something like this:
    Demand
    +Cars
    | +Internal Combustion
    | | +Gasoline
    | | +Diesel
    | +Hybrid
    | +Gasoline
    +SUVs
    3. Finally, select the Current Accounts scenario and then click on the Demand branch. You should see variables (tabs) for both stocks and sales where you can enter your data. Below these branches you can specify the stock and sales shares.
    Tip: stock data only appears in Current Accounts. Stocks are calculated (not entered) in scenarios.
    Tip 2: You may see the activity level variable still appearing. You do not need to specify any data for activity levels if you are using the transport methodology.
    I hope this helps.
  • saeed alaei 8/4/2009
    2263 Views
    dera charles
    your Tips are very helpful,Thank you very much
    saeed
