• 389 views | 3 messages Discussion: LEAP
    Topic: about a single power plant in LEAP Subscribe | Previous | Next
  • BETÜL ÖZER 8/11/2009
    3154 Views
    I wld like to learn if I can work with LEAP for just a single existing thermal power plant individually as applying mitigation projects and scenarios, wld you pls kindly reply?
    Thanks in advance and B.Rgds,
    Betül Özer
  • BETÜL ÖZER 8/17/2009
    3128 Views
    As I'm a new user, is it possible to get an answer for my below question? It is important for my Ph. D thesis begin with LEAP..
    Thanks for your help.
    Rgds,
    Betül
    > Hello,
    > Bet�l �zer
  • Charlie Heaps 8/17/2009
    3126 Views
    It is possible to do this, but I would not recommend it. The benefit of using LEAP really comes from analyzing an integrated system in which you combine a demand side analysis of energy consumption in different sectors with a supply side analysis that look at (for example) different possible scenarios for an entire electric system.
    There IS a fairly significant amount of learning involved in becoming expert with LEAP and I am not sure you would find that justified if all you wanted to do was to study a single power plant.
    Maybe the question to ask yourself is: what questions am I trying to answer? Are they:
    * Should the power plant be built? (in which case an integrated analysis using something like LEAP probably IS worthwhile).
    * Where should a plant be sited for least environmental damage (in which case perhaps you should be using a siting model like the ECOSENSE tool developed for the European EXTERNE project).
    *What alternative generation options make sense (try looking at the RETSCREEN model).
    I hope this helps,
