• 279 views | 2 messages Discussion: LEAP
    Topic: Default Cost units Subscribe | Previous | Next
  • Veena Subramanyam 8/14/2009
    3092 Views
    Hi Charlie,
    The default cost units when specified for some other currency(other than US Dollars) even in the "Basic Parameters" doesn't change the units in the sectors .Do we have to change it each time manualy .
    PS let us know
    Veena
  • Charlie Heaps 8/14/2009
    3091 Views
    >> The default cost units when specified for some other currency(other than US Dollars) even in the "Basic Parameters" doesn't change the units in the sectors .Do we have to change it each time manually .
    Yes I'm afraid so. The basic parameters default only affects new branches as they are added.
    If you want to change all the units quickly for variable you can export all the branches to Excel (using Analysis: Export) then change a unit and copy and paste over all other units.
    Obviously - do this with caution!
