• 413 views | 3 messages Discussion: LEAP
    Topic: Error after upgrading to version 2008.0.0.72 Subscribe | Previous | Next
  • Velimir Segon 2/15/2010
    2662 Views
    I have just upgraded LEAP to version 2008.0.0.72 from the previous version, after which I started to get an error message after trying to view the Results. The error message says the following:
    Error Type: EDatabaseError
    Error Message: Dimensions: Cannot modify a read-only dataset
    Also, when starting LEAP, I get a pop-up window which says 'Internet explorer not found on this PC. Some options may be unavailable'. I have Internet explorer installed on my PC and it is working fine.
    In the previous version everything worked ok, but now I get this message for all areas (both Freedonia and my datasets as well). I have also sent an e-mail through LEAP, using the option offered after the error occured.
    Thanks in advance for your help,
    Velimir Segon
  • Charlie Heaps 2/15/2010
    2661 Views
    Hi Velmir,
    For the IE error message you should be able to click a checkmark that just tells LEAP never to show that message again. It is simply a warning message and can be safely ignored.
    For the other message, could you send your data set to me by email so I can investigate? Please let me know what version you were using previously. Please also check your _work and area folders to make sure none of the files in it are marked as read only.
    I am also about to post another update (v73) with a few further tweaks.
  • Velimir Segon 2/16/2010
    2659 Views
    Hi Charlie,
    I have just downloaded the newer version 2008.0.0.73 and now everything is working ok again - many thanks!
    Velimir
