• 718 views | 5 messages Discussion: LEAP
    Topic: Exercise 5 - Transportation Subscribe | Previous | Next
  • Jim Scheer 2/16/2010
    2675 Views
    In 5.5. i cant get the table to look liek the BAU scenario results.What ever I am doing wrong, I can only see see an 'indexed' result in the table rather than actual emissions as per the table in the exercise. I had no trouble entering the data as required to this point. Can anyone help?
  • Tory Clark 2/16/2010
    2671 Views
    Hi Jim,
    To see the absolute values (i.e. million tonnes CO2e) you have to change a few settings. First you need to show only one pollutant at a time in the Show: Environmental Results: Pollutant loadings drop down menu or Effects drop down menu. Second, you need to click the "More" button and select Absolute from the Values drop down menu (this is where it would otherwise only show indexed).
    If you're still having trouble, feel free to send screen shots to leap@sei-us.org. Hope that helps!
  • Tory Clark 3/3/2010
    2634 Views
    A quick update:
    The completed transport exercise (LEAP training exercise 5) is now available for download from the Training Materials page. See the URLs below.
    Training Materials Page: http://tinyurl.com/LEAP-Training-Materials
    Exercise 5 LEAP file: http://tinyurl.com/FreedoniaEX5
  • Dilip Khatiwada 9/11/2010
    2426 Views
    Hi Tory,
    I tried many times to download exercise 5. But, could not open the file. What is the problem? However, Free-donia is working ok.
    The message appeared is:
    //This webpage is not found.
    No webpage was found for the web address: ftp://forums.seib.org/areas2007/FreedoniaEX5.leap
    More information on this error
    Below is the original error message
    Error 6 (net::ERR_FILE_NOT_FOUND): The file or directory could not be found.//
    Please suggest me.
    Best Regards,
    Dilip
  • Tory Clark 9/12/2010
    2425 Views
    Hi Dilip,
    This could have to do with your security settings or a firewall, because I am able to download those files without a problem. Please try again, and if it continues not to work I can send you the file directly.
