• 236 views | 2 messages Discussion: LEAP
    Topic: Copying on memory stick Subscribe | Previous | Next
  • kamyar jooya 4/1/2010
    3152 Views
    I am working on my assignment on two computers. Today, I saved the work on my memory stick in order to continue the work on second machine. When I copied the file into leap area on second machine most part of my work was not there. I deleted all the previous files with the similar name from leap area and program file but, still didn't work. Could you please help me in this regard.
  • Tory Clark 4/1/2010
    3149 Views
    Hi Kamyar,
    My guess is that all of the files were not copied properly. LEAP files store all required data in the LEAP Areas folder (Documents\LEAP Areas) and require ALL files in that folder to run properly. For this reason, I do not recommend manual copying because you risk losing crucial files. It's also good to check to make sure you have the most recent version of LEAP (Help: Check for Updates).
    I recommend using the Backup Feature in LEAP. To access this feature go to Areas: Manage Areas, highlight the project you want to make a copy of, click "Backup" and select a location (e.g. memory stick) for saving. This will create a .leap file in the specified location. To read more about the Manage Areas screen, please see the user guide documentation here: http://tinyurl.com/y8lg2sr
