2851 Views
			Hi Aria,
Please provide more information on the system you are modeling, the results you expect to see, and what results you are actually getting.
The variable "Output Properties" is where the user defines how to handle shortfalls and surpluses. This variable is found at the "Output Fuels" branch under Transformation processes (e.g. Transformation/Electricity Generation/Output Fuels). This could be set up to import resources to meet a shortfall.
If you are getting unexpected imports, I would refer to the documentation on imports in the user guide, found here: http://tinyurl.com/26qy4n2
It may also be helpful to read up on the LEAP Transformation Analysis, which can be done here: http://tinyurl.com/265y5a3
