• 206 views | 2 messages Discussion: LEAP
    Topic: electricity planning Subscribe | Previous | Next
  • BETÜL ÖZER 5/28/2010
    2817 Views
    Hi Tory,
    Under Transformation- module properties -I can not choose "simple non-dispatched module" as it is inactive. Pls inform how can I make it active and can select. I wld like to create transmission module without "output fuels" and "process share" tab. I have changed once and can not do this.
    Is it possible to delete "any variable tab" on the table pane.
    Pls find my answers below near questions:
    List of information to include in forum post:
    1- What were you doing and what part of LEAP were you using when problem occurred? I were working on"electricity generation- under porcesses and adding new fuels.
    2- Is the problem reproducible and what exact steps would we need to take to do that? hope not.
    3- Operating system version (Windows 2000, XP, Vista, 7, etc.! ) XP
    4- Language and regional number formatting (e.g. 1,234.56! or 1.234,56) - Version of LEAP (check Help: About) now the latest .080
    Rgds,
    Betül
  • Tory Clark 5/28/2010
    2816 Views
    Hi Betul,
    The first property of a transformation module, whether or not it is a simple non-dispacted module, must be set upon creating the module. After the module is created this property cannot be changed.
    The best way to create a transmission module is to create a new transformation module and click on the box next to "simple non-dispatched module." Then you can select whether you would like to include costs and if you want to enter data as efficiencies or losses.
    Variable tabs are automatically created based on the properties selected for specific modules as well as specified parameters in the General: Basic Parameters screen. You cannot manually delete tabs.
