• 694 views | 4 messages Discussion: LEAP
    Topic: LEAP crashing continually Subscribe | Previous | Next
  • Sean Waters 7/20/2010
    2798 Views
    Hi there
    LEAP is continually crashing (20times during completion of Training exercise 1. Error type = EDBEngineError Error message = Permission denied.
    Can anyone help me with how to solve this. I have already downloaded a new version.
    Many thanks
    Sean
  • Tory Clark 7/20/2010
    2797 Views
    Hi Sean,
    In order to understand what is happening I will need a little more information. Please provide as much of the following information as you can.
    1. What were you doing and what part of LEAP were you using when you see this error message?
    2. Is the problem reproducible and what exact steps would we need to take to do that?
    3. What operating system version do you have? (Windows 2000, XP, Vista, 7, etc.)
    4. What version of LEAP do you have? (check Help: About)
    5. Exact text of any error messages you get (in LEAP and Windows)
    6. Have you submitted an error report?
    7. Finally, please verify that you installed LEAP as an administrator.
    To download LEAP properly you must be logged in as the administrator (not another user on the same computer) and then you must run LEAP at least once with these administrative rights so that registry keys can install properly.
    If you want more information on admin rights issues, please see this related forum post: http://tinyurl.com/2axphzc
    2787 Views
    Hi Tory
    Thanks for your reply. Answers to your questions are below as well as the entire error report.
    It occurs when I click on a tab- which one seems random- it has occurred when I click on a branch of the tree in Analysis, Save, and drop down boxes on the data screen. I have been working my way through LEAP training Ex 1 and the error has occurred many times.
    No- it seems random in when it crashes.
    Vista
    2008.0.0.83
    contained in error report below
    error report below.
    > From: seanwaters@hotmail.com
    > Subject: LEAP Error Report
    > To: leap@sei-us.org
    > CC: seanwaters@hotmail.com
    > Date: Tue, 20 Jul 2010 09:59:29 +1200
    > User Email: seanwaters@hotmail.com
    > Error Messages:
    > Error Type: EDBEngineError
    > Error Message: Permission denied.
    > Table: C:\Users\Sean\Documents\LEAP Areas\_Work\GridTable.Yg0
    > User Description of Error:
    > highlighting catagory in the analysis tree
    > System Information
    > LEAP
    > Registered to: seanwaters@hotmail.com until: 05/05/2011
    > User Name: Sean
    > Version: 2008.0.0.83
    > Dictionary Version: 288
    > Program Folder: C:\Program Files\LEAP\
    > Areas Folder: C:\Users\Sean\Documents\LEAP Areas\
    > Settings Folder: C:\ProgramData\LEAP Settings\
    > Work Folder: C:\Users\Sean\Documents\LEAP Areas\_Work\
    > Mapping Components: Not installed
    > Borland Database Engine Version: 5.00
    > Microsoft Windows
    > Version: Windows Vista
    > Windows Directory: C:\Windows
    > Internet Explorer Version: 7
    > Fonts: Small fonts
    > Running as: Standard user
    > Computer
    > RAM: 2048 MB
    > CPU Manufacturer: GenuineIntel
    > CPU Type: P 6
    > CPU Speed: 2157 MHz
    > Number of CPUs: 2
    > Disk Size: 222.8 GB
    > Free Disk Space: 102.6 GB
    > Screen Resolution: 1280 x 800
    Thanks heaps for trying to solve this for me.
    2789 Views
    Hi Sean,
    Your error report shows that you are running as a standard user, not an administrator. To download LEAP properly you must be logged in as the administrator (not another user on the same computer) and then you must run LEAP at least once with these administrative rights so that registry keys can install properly.
    Did you have admin rights to your computer when you installed?
    Additionally, you should set the properties of the LEAP program files folder (C:\Program Files\LEAP) to give full control to all users.
    If LEAP is still not running as an administrator, you can right click on the LEAP.exe file and click "Run as Administrator"
    Another possibility is user account control (UAC) on Windows Vista and Windows 7 machines, which can occasionally interfere with the download and operation of LEAP. You can temporarily switch off UAC by going to the "User Accounts" section of control panel and clicking on "Change User Account Control Settings." Then select "never notify." If LEAP then runs OK you can switch UAC back on and gradually try setting an increased level of security in the UAC settings.
    Let me know how this goes,
