• 813 views | 4 messages Discussion: LEAP
    Topic: EOleSysError?? Subscribe | Previous | Next
  • Stephan Leinert 7/22/2010
    3647 Views
    Good morning,
    I am trying to export data to excel, I get the export screen, click ok, and then the error message:
    Error Type: EOleSysError
    Error Message: Call was rejected by callee
    closing and restarting leap does not help.
    Is there a fix for this?
    Leap version 2008.0.0.78
    Windows XP
    Thanks for your help,
    Stephan Leinert
  • Tory Clark 7/22/2010
    3646 Views
    Hi Stephan,
    I will look into this error.
    In the meantime I suggest you upgrade to the latest version of LEAP (v.0083) and see if this fixes the problem. You can update using the Help: Check for Updates option in LEAP or from the COMMEND website here: http://tinyurl.com/2b75q87
    3646 Views
    Hi Stephan,
    This error occurs when Excel is busy for some reason. It could be as simple as you being in mid edit of a cell value.
    When you get this error message, check to see what you are doing in Excel rather than in LEAP.
    Though this problem isn't related to having the latest version of LEAP, it's always a good idea to upgrade since we add bug fixes to each new version.
  • Stephan Leinert 7/23/2010
    3643 Views
    Thanks, it is working again!
    Stephan
