• 501 views | 3 messages Discussion: LEAP
    Topic: errors wiht the new version 88 Subscribe | Previous | Next
  • Deleted User 9/5/2010
    2272 Views
    I updated the version from 83 to 88. I do not change anything about my modal, but the results of environmental emissions such as co2,NOx and PM10 would increase 1000 times, the unit was changed from kg to tonnes unaccountably. So I had to install the 83 version again.
  • Tory Clark 9/6/2010
    2266 Views
    Jian Zhou,
    Can you provide me with a little more information? What specific values (with units) are you expecting to see and what do you actually see? Are you seeing this in results view?
    The default units provided in the results view may not be exactly what you are looking for, in which case you should click on the unit box and select another unit. 1000 kilograms is equal to one tonne, so it is possible that changing the unit will give you the values you expect.
  • Deleted User 9/6/2010
    2262 Views
    Hi Tory, I had given your an email to show my problems in detail.
