5005 Views
			Hi Ralph,
I apologize for the delayed reply. It sounds to me like the first setup.exe file did not install completely or properly from internet explorer. This could mean that there is an issue downloading from Internet Explorer (in which case, I suggest upgrading to the latest IE or downloading from a different browser such as Mozilla Firefox or Google Chrome) or that there is an issue with administrative rights. Though you have checked the security settings on the ...\All users\ subdirectory, I suggest you also check the following things:
1. Make sure that you are the administrator (not a regular user on the same computer) by going to Control Panel > User Accounts and see if the user type is "Computer Administrator."
2. I suggest you also delete the LEAP Settings Folder (C:\Documents and Settings\All Users\Application Data\LEAP Settings) and try to install again.
3. After installing, check to see if you have full security permissions to the specific "LEAP Settings" folder by right clicking on it and ensuring that the folder does NOT have the "read-only" attribute. I suspect the LEAP error that you are getting is because of an inability to write files to that directory.
4. You could also try running the setup.exe file as an administrator (right click "Run as" and choose the administrator option).
If you continue to have this issue, please let us know and provide any error messages you receive along the way. If you are still having issues we will investigate further.
