• 267 views | 2 messages Discussion: LEAP
    Topic: Clarifications in Transformation section Subscribe | Previous | Next
  • Sarada Ramaswamy 1/10/2011
    2761 Views
    Hi
    I need some clarifications
    1) How and where do we consider coal washery process and coal washery rejects in LEAP?
    2) Do we consider natural Gas flaring in transformation section under T & D losses?
    3) In the electricity generation section(under transformation), do we enter gross or net (after reducing auxiliary power consumption) electricity generated under historical production?
    Sarada
  • Tory Clark 1/11/2011
    2751 Views
    Hi Sarada,
    I will answer each of your questions individually.
    1. I assume you are talking about improving the quality of coal by “washing” it with water and chemicals to remove sulfur and impurities before it can be burned in a power plant. LEAP does not take into account water usage or water contamination due to energy-related processes at this time.
    2. I have not ever attempted to model the methane emissions of natural gas flaring in T&D losses. I would imagine that it is possible, though. I suggest that you experiment with a few different methods and let me know (just post a response to this message) if you run into any snags. Also, if any other users have tried this, please post your solutions or advice.
    3. For historical production, you should enter net electricity generated, because LEAP does not use power plant performance variables to calculate output for historical production. To read more about how LEAP uses transformation variables, see the documentation in the user guide.
    e.g. Historical Production Variable: http://tinyurl.com/24vlsx2
