• 513 views | 4 messages Discussion: LEAP
    Topic: LEAP 2011 Subscribe | Previous | Next
  • BETÜL ÖZER 3/3/2011
    2631 Views
    1- Please don't forget to correct diagram view as it shld be following "electricity generation" to "transmission" and to "distribution" when transmission and distribution are seperated.
    2-Is it possible to open files more than 1, as I need to get some infos from another LEAP file?
    3- Is it possible to make more clear the "electricity generation" calculations?
    Rgds,Betül
  • Tory Clark 3/3/2011
    2630 Views
    Hi Betül,
    LEAP 2011, which will be released later this month, will address some of these issues. Below are more specific answers to your questions:
    1. Based on the feedback we have gotten from the larger user community we are devoting our energy to integrating the new optimization functionality into LEAP. This bug in the diagram view is not a priority for this first release.
    2. This will be possible with LEAP 2011. This new version of LEAP installs in a different folder than the existing version. You can continue to use the older version alongside the newer version, and you can also run both simultaneously so you can compare results.
    3. We are currently working to have a complete documentation of the new components of LEAP 2011 for the full release later this month.
    For more information on the new version, please see the latest blog post:
    http://blog.energycommunity.org/2011/02/coming-soon-leap2011.html
    Please ensure that you are subscribed to the Announcements forum (check Members: Edit My Discussion Prefernces on COMMEND) to ensure that you are notified once the new version is released.
  • BETÜL ÖZER 3/4/2011
    2623 Views
    Hi Again,
    I wld like tell a few things for new version:
    1- Is it possible to make an "undo" option?
    2- And is it possibleto see results as:
    transformation output (from results view), electricity generation and total transformation from energy balance view in a same screen. In latest version (..094), these results can be seen in different views. It will be great to see all electricity generation (as all process' outputs with all losses, to check the all calculations bottom up to demand)
    Rgds,
    Betül
  • Tory Clark 3/7/2011
    2612 Views
    Hi Betül,
    1. An undo feature will not be added in the first version of LEAP 2011. However, one of the reasons we are switching to the new file format is that we expect the new flexibility to lend itself to adding features like that in the future.
    2. You cannot see that exact combination of tables, but you can use the "Overviews" view to look at any combination of charts or tables that you format in Results view.
    To read more about overviews, please see the user guide documentation:
    http://tinyurl.com/6d4dz9l
