• 382 views | 3 messages Discussion: LEAP
    Topic: Expression Builder Subscribe | Previous | Next
  • Zhang Tanya 3/17/2011
    2309 Views
    Hi, I am using LEAP to build a model, when I use the Expression builder, an error "Reference to unit can not be changed in expreesion"came out,but other similar expressions can be used, some can not。I need you Help!
    thank you!
    Tanya
    The problem is resolved.Change language will be OK.Thank you.
  • Tory Clark 3/17/2011
    2302 Views
    Hi Zhang,
    It's not clear to me if you have resolved the issue you raised.
    If you are continuing to get this message, can you please give me some more information such as the branch, variable and specific expression you are trying to edit?
  • Zhang Tanya 3/18/2011
    2297 Views
    Hi,Tory,
    Thank you for your letter.I have resolved my problem already.I think the error came out because of the language I chose.After switching the language ,everything went well.Thank you.
