• 810 views | 8 messages Discussion: LEAP
    Topic: can't open old version the Nepal_Leap into LEAP ver11 Subscribe | Previous | Next
  • Amrit Nakarmi 5/22/2011
    3253 Views
    Dear Charlie
    I tried several times to bring in the Nepal data file saved in the older version into LEAP ver11. I zipped the data files in .rar.
    Amrit Nakarmi
    Center for Energy Studies
    Institute of Engineering
    Tribhuwan University
    Pulchowk, Lalitpur
    Kathmandu, Nepal
  • Tory Clark 5/23/2011
    3248 Views
    Hi Amrit,
    LEAP currently does not open .rar files. I'm afraid you will need to save the files as .zip or .leap files.
    As long as LEAP2008 is still installed on your computer, you can save the file to any location on your computer by going to Area: Manage Areas and selecting the backup option. This will allow you to save the file as a .leap file. Then you will be able to open it directly in LEAP2011.
  • Amrit Nakarmi 5/24/2011
    3245 Views
    Hi, Tory
    Thanks, I could install my Nepal_Leap into LEAPver2011 but when I wanted to go to the result view and energy balance.The calculation showed an error message:
    Error: Access violation at address 0120ED4B in 'Leap.exe'. Read address 00000000.
    Request your kind help
    Amrit
  • Tory Clark 5/24/2011
    3242 Views
    Hi Amrit,
    Thank you for the additional information and for sending an error report. Your error report informs me that you currently have version 2011.0.0.12. Please first update to the latest (2011.0.0.15) by going to Help: Check for Updates.
    If this does not fix the problem, please check your admin rights as it seems that you are running LEAP as a standard user, not an administrator (see below).
    On all Windows machines, administrative rights can interfere with the proper installation and operation of LEAP.
    To download LEAP properly you must be logged in as the administrator (not another user on the same computer) and then you must run LEAP at least once with these administrative rights so that registry keys can install properly.
    Next you should set the properties of the LEAP program files folder (C:\Program Files\LEAP) and LEAP Settings folder to give full control to all users. For more information on where LEAP files are stored, please go to General: Basic Parameters and click on the folders tab.
    If LEAP is still not running as an administrator, you can right click on the LEAP.exe file and click "Run as Administrator"
    3240 Views
    Hi Tory
    I did install LEAP version 2011.0.0.15 and right clicked on the LEAP.exe file and clicked "Run as Administrator". But still I had the same error as before while clicking on Results view.
    Amrit
    3239 Views
    Hi Amrit,
    Can you confirm for me that you are the administrator on your computer? In Windows 7 this means going to Control Panel: User Accounts: Change Your Account Type and verifying that you are the administrator?
    If so, please send me your dataset at leap@sei-us.org so that I can investigate further.
    If not, please make your user account an administrator account and reinstall LEAP 2011. Then see if the error persists.
  • Tory Clark 5/27/2011
    1 Like 3227 Views
    Thank you for emailing your data set, Amrit.
    Firstly, "Power" is now a reserved word in LEAP2011, so none of your branches may contain this string. First you must change the names of two of your electricity generation processes to not include the word "Power."
    Secondly, it seems that you found a small bug in LEAP.
    The Access Violation error should now be fixed in the newest version of LEAP (2011.0.0.16). You can update by going to Help: Check for Updates within LEAP or by downloading from COMMEND here: www.tinyurl.com/LEAPDownload
  • Amrit Nakarmi 5/27/2011
    3225 Views
    Thanks a lot, Tory.
    It's working now and I have changed Hydropower plant to hydro plant since "power" is a reserved term. I need to update and upgrade my Nepal_Leap model.
    Thanks once again.
    With warm regards
    Amrit
