• 504 views | 5 messages Discussion: LEAP
    Topic: Iterations have no effect / system not converge Subscribe | Previous | Next
  • Alexey N 5/26/2011
    2114 Views
    Hello, Tory!
    I've set up the demand and transformation,
    and when choosing "energy balance"
    it shows the following list.
    http://ru.magicscreenshot.com//MagicScreenshot/1arWEgLA30A.png
    It looks like all the values in Iterations stay same,
    except for Heat_Yak which unexpectedly increases!
    Please let me know where to look to fix that.
    Thank you,
    Alex
    Russia
  • Tory Clark 5/27/2011
    2105 Views
    Hi Alex,
    Thank you for your inquiry. It seems that LEAP thinks it should be iterating and it should not be.
    I recommend going into General: Basic Parameters on the Calculations tab and switching off the first 3 check boxes:
    - Check unmet requirements
    - Check surplus production
    - Meet auxiliary energy needs ...
    Then see if you continue to get the same diagnostics. If you do, please give me a bit more information on the issue by filling out a problem report (url below) as completely as possible.
    www.tinyurl.com/LEAPProblemReport
  • Alexey N 5/27/2011
    2103 Views
    Tory,
    thank you for advice!
    I removed the checkboxes and now LEAP shows the balances!
    Does it mean that it is okay to not put those checkboxes back?
    Or should i do it when I get the balance correct by adjusting the system and fixing errors?
    Thank you!
    Alex
    2102 Views
    For most simple analyses leaving them unchecked will be fine.
    2100 Views
    I see! Thank you very much!
