Hi Betül,
This is related to your other question that I responded to earlier today. Since LEAP is demand driven, LEAP will always run power plants to try to meet electricity demands. In your case (in your Tez model) you are dispatching power plants to run to full capacity, which means that generation can be the same in each year if capacity and availability is the same in each year.
The most simple electricity generation calculation (assuming running to full capacity) is below:
Electricity generation (in one year) = Capacity in that year (exogenous + endogenous) * Maximum Availability * 8760 (# hours/year)
This means that if capacity and availability are the same in a given year, the outputs can be the same. The above equation will of course get more detailed as complexity is added related to system load curves and dispatch rules.
As I mentioned in my previous response (http://tinyurl.com/3rem9gu), efficiency and auxiliary fuel use govern how much fuel is required to produce a particular output. So if auxiliary fuel use or efficiency change in a given year the inputs may be different for the same output.
