Thank you for the information,
It appears that there is a small bug associated with the iterating calculations for auxiliary fuel use within a transformation process.
For now, there is a work-around. You can go to the Basic Parameters: Calculations screen and un-check (switch off) the "Meet auxiliary energy needs form output of same process where possible" option. This is the component that is not working correctly. If you leave this off, the calculations should iterate correctly.
We will investigate a solution to this bug and I will let you know when it is fixed.
Additionally, I recommend updating to the latest version of LEAP (2011.0.0.26) to stay up to date on other bug fixes and features.
