• 431 views | 3 messages Discussion: LEAP
    Topic: Problem with LEAP.2012.0.0.35 Subscribe | Previous | Next
  • Norberto Fueyo 2/20/2013
    1763 Views
    I have updated my LEAP version to 2012.0.0.35. After that, I have had the following problem described next.
    1) First, I configure the case and run the program to calculate the results.
    2) After reviewing the results, I come back to "Analysis", to the Transformation folder.
    3) But, when I want to change some parameters in the Transformation Folder, I can't access to the information. The only available information are the notes.
    Can you help me with that problem? If it is neccesary, I can attach a capture of the LEAP window when I have this problem.
    Now, I have to finish quickly a project. So, maybe a provisional (and quick) solution could be to come back to the previous version (LEAP.2012.0.0.34). Is this possible? and How could do this?
    Thank you in advance for your help,
    Norberto.
  • Tory Clark 2/20/2013
    1761 Views
    Hi Norberto,
    Thank you for the post. We have identified this bug and are currently working on a fix. We will post here when a new version is available (hopefully later today).
    1760 Views
    LEAP 2011.0.36 is now available and addresses this issue. We encourage all users to update to the latest version of LEAP.
    www.energycommunity.org/download
    You can also get the new version from within LEAP by going to the Help: Check for Updates menu.
