• 589 views | 4 messages Discussion: LEAP
    Topic: Problem to connect LEAP to a GIS file Subscribe | Previous | Next
  • Tiberiu Stefan 3/1/2013
    1790 Views
    I want to connect LEAP to a GIS Shape File.
    I have installed LEAP’s optional mapping components (see below):
    System Information
    Registered to tiberiu.stefan@gmail.com until January 23, 2015
    User Name: tiberiu.stefan
    Version: 2012.0.0.37
    Dictionary Version: 337
    Program Folder: C:\Program Files (x86)\LEAP2012\
    Areas Folder: C:\Users\tiberiu.stefan\Documents\LEAP2011 Areas\
    Settings Folder: C:\...\Documents\LEAP2011 Areas\_LEAP Settings\
    Work Folder: C:\...\Documents\LEAP2011 Areas\_Work\
    First Instance: Yes
    First Instance: Yes
    Mapping Components: Installed
    I am working on a multi-region area (in General/Regions I added 2 new regions in my work area).
    When I try to connect LEAP to a GIS shape file, this error message appear:
    "Error #5 (File access denied)
    Failure to open C:\Program Files(x86)\LEAP2012\LEAP\MAPS\Countries\country.dbf (USE/OpenDbf"
    What is wrong?
    Thank You in advance!
    Tiberiu
  • Maria Shrestha 2/5/2014
    1308 Views
    I also have the same problem. Anybody can help?
  • Taylor Binnington 2/6/2014
    1306 Views
    I can reproduce the problem, and will look into resolving it. Thank you for pointing it out, and I'll be back in touch shortly.
  • Taylor Binnington 4/3/2014
    1200 Views
    Hi Tiberiu and Maria,
    Sorry for the long wait on this. File access is denied because the shape file that you are trying to load is in a directory on your computer that requires Administrator permissions to access.
    You can get around the issue either by running LEAP as an administrator (right click on the *.exe file and select 'Run as Administrator'), though this is not the recommended course of action, or better, make a copy of the mapping files in your Documents folder. Then point LEAP to the shape file in this folder.
