• 519 views | 4 messages Discussion: LEAP
    Topic: Execise 1 (1.4.2.1) Can't change the Endogenous Capacity Subscribe | Previous | Next
  • Jorge Vidoza 5/30/2013
    1864 Views
    Hi everyone
    I'm new on this, and trying to do the tutorials by myslef
    I'm stuck in the 1.4.2.1, it says that new plants of 500MW (Coal) and 300MW (Diesel) are going to be installed. But when I add those on the REF scenario I can't change the "Addition Size Expression" which appears to be 0. Did I forget to do something? or could be my pc configuration?
    Some advice would be great
    Greetings!
  • Charlie Heaps 6/4/2013
    1859 Views
    Hello Jorge,
    I suspect that you are (or were) running LEAP in evaluation mode. You need to have a fully enabled (licensed) version of LEAP before that screen will allow you to edit data there. If you are in evaluation mode, a red message will appear in the status bar at the bottom of the main LEAP window.
    I see you have applied for and been granted a license so perhaps you have already solved this?
    Pleas let me know by replying here.
    I hope this helps,
  • Jorge Vidoza 6/4/2013
    1857 Views
    Hello Charlie
    Yes, indeed it solved when got the licensed version, thanks so much for the support, I will start doing my analysis and could (for sure) have some more doubts on the way, hope to keep in contact with you
    Greetings!
    Jorge
    1856 Views
    Thanks (and thanks also for replying to clear that up - much appreciated!)
