• 247 views | 2 messages Discussion: LEAP
    Topic: Question about exercise 6.3.1 Subscribe | Previous | Next
  • Yuan Liu 6/5/2013
    1738 Views
    Hi everyone,
    When I do the exercise 6.3.1. The result i got and the result showed from the exercise was not the same. my result only show the capital cost, no demand, no fixed O&M, no variable O&M cost etc(the value maybe were zero?). I check my model many times, and cannot find the problem. May you help me?
    Thank you very much!
    Yuan
  • Taylor Binnington 6/19/2013
    1696 Views
    Hi Yuan,
    Sorry for the delay getting back to you. It's difficult to say why you're not seeing quite the same results without a bit more information.
    It shouldn't matter if the O&M costs are zero, so long as they've been properly included in your analysis, they should at least appear in your chart's legend. Perhaps you haven't properly selected all Area branches (by clicking Optimization Exercise at the top of the tree) when you display your results?
    You can also load the completed optimization exercise into LEAP (comes standard with new installations) and compare it with your model, step by step.
    Hope you find the problem,
