• 253 views | 2 messages Discussion: LEAP
    Topic: Freedonia Subscribe | Previous | Next
  • Denis Lavigne 7/8/2013
    1857 Views
    Practicing with LEAP for the first time, I changed some data of the original Freedonia. I should not have done this and should have followed the training that says to create a "New Freedonia" first. This being said, is there a way to get the original Freedonia model default values? Sorry to ask such a bad first question about LEAP... I'll get better! Thanks.
  • Charlie Heaps 7/9/2013
    2 Likes 1856 Views
    Hi Denis,
    You can use the Area: Revert to Version menu option to restore different set versions of the Freedonia data set. I think it has versions that match each major milestone in the exercises.
    One reason to make your own area for the exercises (eg "New Freedonia") is that the Freedonia area is a special area that by design gets completely overwritten any time you re-install or update LEAP. So if you are working on it and re-install LEAP you are in danger of losing all your work.
