1775 Views
			Hi Jorge,
I think that there could be a few reasons that you're seeing this outcome. A careful read of the Output Fuel Properties online help should address your question, I hope.
http://www.energycommunity.org/WebHelpPro/Wizards_and_Properties/Output_Fuel_Wizard.htm
I'm assuming that you've explicitly specified Crude Oil as an output fuel, within some sort of an Oil Refining module? In that case, make sure that the three rules for the Crude Oil output fuel are set properly for your purposes: it sounds like you want the "Priority use of output" to be "Exports", the "Surplus Rule" to be "Export Surplus", and the "Shortfall Rule" to be "Requirements remain unmet". That way if, as your demand grows, there is insufficient crude to export directly as crude oil, the remainder of your Export Target will remain unmet.
Hoping I've scraped the surface of your question!
