• 808 views | 4 messages Discussion: LEAP
    Topic: Where is it saved? Subscribe | Previous | Next
  • Denis Lavigne 8/8/2013
    1 Like 1869 Views
    When we save an area (for example Freedonia), where is it saved on the disk? For example, how can I put a new "area" on a USB key or e-mail it to someone?
  • Taylor Binnington 8/8/2013
    1868 Views
    Hi Denis,
    LEAP saves areas in a folder with the name of that area, inside your "LEAP2011 Areas" folder (likely in Documents, depending on your install directory).
    To email it to a colleague, click 'Backup' from within LEAP, which will create a *.leap file and ask you where to save it. This file can then be opened by others from clicking Area: Install: Install from file in LEAP's main menu.
    1866 Views
    This is just the perfect answer I was looking for.
  • 飞雪 郭 8/9/2013
    1857 Views
    Thank you! now I can use it .
