• 461 views | 3 messages Discussion: LEAP
    Topic: Optimization file installation Subscribe | Previous | Next
  • Subhash Mallah 8/25/2013
    1957 Views
    Hello Friends,
    I have installed the latest version of LEAP 2012.0.0.49 on my laptop. When I go to check the OSeMOSYS is properly installed through General -Basic Parameter- Optimization...
    I find the following:
    GNU Linear Programming Kit : File Missing: C:\ Program Files (x86)\LEAP2012\w64\glpsol.exe
    I want to ask if the optimization software is properly installed? If not please help me to install properly.
    Thanks in advance for the help.
  • Charlie Heaps 8/26/2013
    1953 Views
    Hi Subhash,
    I'm guessing you are upgrading from another version of LEAP and have missed the special instructions we posted on the "What's New" page. I am listing them again here for your information:
    IMPORTANT: To fully update to this new version, download and run the full setup file (from the LEAP web site). LEAP's Help: Check for Updates menu option can also be used but does not automatically update the components needed for optimization calculations. If updating using Help:Check for Updates. After the update completes you can manually unzip the w32.zip and w64.zip files in the LEAP program folder to create two new folders w32 and w64.
    So in short - look in the \program files (x86)\LEAP 2012 folder and then unzip the w32.zip and w64.zip files to make new folders (w32 and w64).
    I hope this helps!
    best,
  • Subhash Mallah 8/27/2013
    1 Like 1936 Views
    Hi Charlie,
    Thanks for your support. I followed the process as you described and i think it works because now it says:
    GNU Linear Programming Kit : Installed (64 bit).
    Thank you so much again for your quick help.
    Best Regards
    Subhash
