• 521 views | 3 messages Discussion: LEAP
    Topic: Change unit of the user variable "Total Energy" Subscribe | Previous | Next
  • Gregers Larsen 9/3/2013
    1974 Views
    I have a huge problem. Apparently (for me) there is no way to change the unit "Total Energy" when from Thousand TOE, which is not the unit my data is in.
    It does not make logical sense why you cannot change this unit. I tried the different ways that otherwise works with other inputs, being looking into Properties or changing the unit in a step further up the tree. Nothing works. How can I change this crucial unit?
    It is within Total Energy in a normal folder in Demand.
  • Charlie Heaps 9/3/2013
    1971 Views
    Hi again,
    I think you are referring to a User Variable named "Total Energy". With User variables, the units are simply text fields. You can edit these by right-clicking on the tab for the variable in Analysis View. This brings up a menu that let's you edit the Variable's properties. You can also get access to all User variables via menu option Analysis: User Variables.
  • Gregers Larsen 9/24/2013
    1909 Views
    I think the error was on my side. I was trying to use the "Total Energy" marked in blue, which caused problems. Using the grey tab, I was able to fix units and get results. I am still not aware of the difference between the two, but no matter.
    Gregers
