• 671 views | 4 messages Discussion: LEAP
    Topic: Error Message: "Invalid Array Index" Subscribe | Previous | Next
  • Rahmat Al hasibi 10/4/2013
    1974 Views
    Dear Sir,
    I had an error message of "Invalid array index" when I tried to view map result.
    Any suggestions?
    Thank you very much.
  • Taylor Binnington 10/4/2013
    1973 Views
    Hello Rahmat,
    This sounds like an error that is lower-level than a LEAP error, which means that we're not certain what could be causing it.
    Could you include some more context, including exactly what you were doing when the error occurred, as well as your operating system information? For a few helpful details to include, please refer to our Posting Guidelines:
    http://www.energycommunity.org/default.asp?action=184
    Thank you, hopefully we'll be able to help you further!
  • Rahmat Al hasibi 10/7/2013
    1964 Views
    Dear Taylor,
    I had this message when I was trying to view the result using LEAP map component.
    I use the most recent version of LEAP and running in windows 8 professional.
    Thank you.
  • Taylor Binnington 10/7/2013
    1963 Views
    Hello Rahmat,
    Thank you for the information, and sorry you're having trouble. We'd really appreciate it if you could help us determine if the error is coming from LEAP, or from something outside LEAP.
    If you can reproduce the error, and an error dialog box appears in LEAP asking you if you would like to send an error report, could you please proceed and submit the error to leap@sei-us.org? This will provide us with important information, to try to address the issue in a future version of the software.
    If the error screen does not give you an option to send us the error report, would you be able to send a screen capture of the message you're receiving?
    Thanks for your input,
