• 668 views | 4 messages Discussion: LEAP
    Topic: viewing results Subscribe | Previous | Next
  • Aba Crentsil 10/14/2013
    1894 Views
    Hi Taylor
    Please my outputs graphs do not show the bar for year 2010 i have then all that you suggested but do not get any bar for year 2010 when viewing my graph for electricity generation . apart from that every thing is o.k.
    warm regards
    Aba
  • Taylor Binnington 10/14/2013
    1893 Views
    Hi Aba,
    There are many different reasons that you could be seeing these results, so I don't want to speculate too much and lead you in the wrong direction. The simplest explanation would be that you haven't specified any historical electricity generation, using the 'Historical Production' tab for your electricity generation process.
    My best advice, if you're working through the exercises, would be to select Area:Revert to Version to revert your training exercise to a completed version of the same module. That way you can compare your intermediate results with those of the completed exercise, and see where they differ.
    Good luck,
  • Edito Barcelona 1/30/2014
    1711 Views
    I encountered the same problem as the thread starter. I am using the latest version 2012.0.0.55. Sometimes the current account values appear in the Results but there are also times that they don't appear. The current account values should always appear when the user want them to be but it is not always the case.
    I believe this is a bug. Please let me know if you are aware of this.
    Edito
  • Charlie Heaps 1/30/2014
    1710 Views
    Hi Edito and Aba,
    Sorry for the problems. It certainly sounds like a bug. Here is one possible (short term) workaround: Select menu option Area: Force Whole Area to Recalculate. This should force everything to be recalculated including the missing Current Accounts results.
    In the (slightly) longer term, please note that I am working hard to finish a new version of LEAP (2014) that should fix this problem and should also be much faster. I am hoping that calculations will be at least 3x faster. I am hoping to have this new version ready for testing in about a month.
    Best wishes and sorry again for the problems.
