• 628 views | 4 messages Discussion: LEAP
    Topic: problems in units in result view Subscribe | Previous | Next
  • Suman Raj Manandhar 10/23/2013
    2029 Views
    i have been working with the transportation model with the following structure
    1.PASSENGER
    >intracity
    >intercity
    2.FREIGHT
    >capital city
    >rest of the nation
    when i click in the intracity branch in ANALYSIS VIEW, the chart (or table) shows correct results with billion passenger km as the unit. for eg:(15.4 billion P-KM)
    but when i run the calculation and try to view the activity level of the same branch but from RESULT VIEW, the chart shows same number but reduced unit. (15.4 P-KM instead of 15.4 billion P-KM)
    i get the same kind of problem with the freight branch. I have checked the formula and also run the calculation in excel with same data but its alright in there..
    please help !!!
  • Taylor Binnington 10/23/2013
    2028 Views
    Hello Suman,
    I'm not sure I follow you - the Activity Level itself is not a Results variable. Are you looking at Demand: Energy Demand Final Units, somehow?
    Can you clarify for me which results you're looking at in Results view?
    Thank you,
    2023 Views
    hi taylor,
    okay.. i got the point.. i should be looking at total activity instead of activity level in result view.. but can you clarify what's the difference between them?
    suman
  • Taylor Binnington 10/24/2013
    2022 Views
    Okay, I think I understand you're trouble. I apologize if my comment about the 'Activty Level' not being a Results variable is misleading - it may not be a calculated result, but you can still view it for a demand branch in Results view by selecting Data variables: Activity Level. Note that you'll just be viewing the same data that you entered in the Analysis view, though.
    Total Activity for a branch is calculated by multiplying through each of the activity levels at demand branches above that branch in the tree. This help file describes the difference well:
    http://www.energycommunity.org/WebHelpPro/Demand/Total_Activity.htm
    So, an Activity Level of 20% saturation for refrigerators translates into a Total Activity of 800,000 refrigerators.
    Hope that's clear,
