• 312 views | 2 messages Discussion: LEAP
    Topic: Cannot open National Starter Data with New Version of LEAP (2012.0049) Subscribe | Previous | Next
  • Jambaa Lkhagva 10/27/2013
    1949 Views
    Hello, A error message is showed when i try to open downloaded "national starter data" with New version of LEAP,
    the message is "Installing and converting older format area is unavailable to standard windows users......".
    How can i fix this problem?
    Best Regards,
    Jambaa Lkhagva
  • Taylor Binnington 10/28/2013
    1948 Views
    Hi Jambaa,
    Try the following: before starting LEAP, right-click on the LEAP icon and select 'Run as Administrator', which will load LEAP as a Windows administrator. Then trying loading the data set as normal. It should automatically update for compatibility with the most current version of the software.
    If this doesn't work for you (or perhaps you do not have administrator rights on your computer), watch for a direct email from me with a newer version of the data set.
    Take care,
