• 325 views | 2 messages Discussion: LEAP
    Topic: An error message Subscribe | Previous | Next
  • Maha Alsabbagh 10/29/2013
    2051 Views
    Hi Taylor, I was wondering if you have made any changes in LEAP since yesterday. Because it was working fine yesterday, and now it gives me this error message:
    Error: Socket Error # 10061
    Connection refused.
    Type: EIdSocketError
    File: IdStack.pas
    Module: IdStack
    Line: 679
    Process: TIdStack::RaiseSocketError
    I'm using LEAP at a university with a firewall. The IT people here ask about which IP / port you're using so they can add it to the safe list (if the firewall happens to be the problem).
    Thanks.
  • Taylor Binnington 10/29/2013
    2050 Views
    Hi Maha,
    This is very likely a problem with your university firewall, so I think you were right to speak to your IT support group. Have a look in Basic Parameters: Internet to see the FTP and SMTP ports that LEAP uses (by default, the FTP port is 21 and the SMTP port is 25). Also, by default, the HTTP port used is 80.
    Good luck getting up and running!
