• 403 views | 2 messages Discussion: LEAP
    Topic: Changing Branch Type from Technology Branch to Category Brach Subscribe | Previous | Next
  • Muhammad S 11/11/2013
    1974 Views
    Dear
    i am working on exercise 2.
    under Iron and Steel Category branch, i had added technology branch Process Heat. Now I want to change this technology brach type to Category Branch type. I tried to do from brach properties but could not do so.
  • Taylor Binnington 11/14/2013
    1972 Views
    Hi there,
    LEAP does not allow you to change the type of branch in this way, if there are branches immediately neighbouring your heat technology branch that are also of the type 'Technology with energy intensity'. You must first remove the neighbouring branches (meaning, those branches which are located at the same indentation level in the demand tree) before you can change your technology with energy intensity into a demand category.
