• 301 views | 2 messages Discussion: LEAP
    Topic: Optimization Example Partial.leap Subscribe | Previous | Next
  • Denis Lavigne 11/12/2013
    2052 Views
    Is it possible to get the "Optimization Example Partial.leap" file as mentionned on page 69 of the training material?
    Denis
  • Taylor Binnington 11/12/2013
    2051 Views
    Hi Denis,
    There is indeed a way - select Area:Revert to Version:Starting Point of Optimization Exercise, from LEAP's main menu. This will revert to the beginning of the exercise. If you've done any work on the built-in LEAP file 'Optimization Exercise' before you revert versions, be sure to save your model under a different name before performing the revert to version.
