• 334 views | 2 messages Discussion: LEAP
    Topic: Exercise 3- Will Exogenous Capacity will be zero after its lifetime Subscribe | Previous | Next
  • Muhammad S 11/15/2013
    1928 Views
    Dear
    The generation process in the transformation module asks for the Exogenous Capacity and LIfetime. If I enter Exogenous Capacity as 100MW and its Lifetime as 30 years (in current year/base year 2010 and inherit the same in the reference scenario till2050). will this Exogenous capacity will be zero after 30 years, mean in year 2040 or I need to do retiring the unit manually in the reference scenario.
    if required to do manual, then what is the us of this entry for Lifetime of the plant/unit of power generation.
  • Taylor Binnington 11/19/2013
    1924 Views
    Hi Muhammad,
    Exogenously-specified capacity does not retire automatically. This variable is used to specify exactly how much existing/planned capacity exists in each year, giving full control to the user.
    The 'Lifetime' variable is used for endogenous capacity. See here:
    http://www.energycommunity.org/WebHelpPro/Transformation/Lifetime.htm
    For specific questions about LEAP's variables or functions, have a look through our online help guide, http://www.energycommunity.org/WebHelpPro/LEAP.htm.
