• 272 views | 2 messages Discussion: LEAP
    Topic: modifying the charts Subscribe | Previous | Next
  • Suman Raj Manandhar 11/24/2013
    1906 Views
    can we modify bar chart using different patterns (like in MS-word) rather than using solid color. Because with solid color I often get bad print outs..
  • Taylor Binnington 11/25/2013
    1905 Views
    Hi Suman,
    You can either try the 'Gray scale' color palette for your charts, or you can modify each data series individually. To do this, in Results view, select Chart: Advanced, from LEAP's main menu, then in the dialogue box that appears, select the series you want to modify (the fuel, or the branch, or the scenario, etc - whatever is being displayed). Under the nested Format: Format tab, you should see an button called 'Pattern', which allows you to choose a pattern to be displayed over top of the color scheme.
    Hope this is what you're looking for!
