• 238 views | 2 messages Discussion: LEAP
    Topic: The different between input Process Share vs actual Process Share Subscribe | Previous | Next
  • Muhammad S 1/29/2014
    1798 Views
    Dear
    I have used certain Process Share figures but when I run the model see the result each process share in the output fuel it does not match to what i have input. can you please explain, what the percentage shares means in the output.
  • Taylor Binnington 1/29/2014
    1796 Views
    Please try to be clearer when you post questions - sometimes I have to guess at what question you're asking, and I don't want to mislead you.
    Have a look at this help file for a description of dispatch by Process Share:
    http://www.energycommunity.org/WebHelpPro/Transformation/Process_Dispatch_Rules.htm
    You will need to ensure that each process has sufficient capacity, and sufficient availability, to fulfill the requirements imposed on it my the 'PercentShare' dispatch rule. Even if you specify that 50% of your output comes from a single process, if that process has not been assigned enough capacity, it will be unable to generate 50% of the module's requirements.
    Hope this helps, but feel free to clarify your question.
