• 902 views | 5 messages Discussion: LEAP
    Topic: LEAP model export and import Subscribe | Previous | Next
  • Metin Caliskan 2/10/2014
    2272 Views
    As a beginner, I have two questions:
    Q1:
    OSeMOSYS provides the model in TXT (normal and short version) and a data file which is related to the fictive country "UTOPIA."
    I would like to know if it's possible to import UTOPIA.dat in LEAP? If yes how? If not what is the best way (software) to visualize the results?
    Q2:
    LEAP provides many examples such as FREEDONIA. I know that LEAP uses OSeMOSYS to solve the optimization problem. Therefore, I've heard that LEAP creates a suitable .txt model file for OSeMOSYS model. Can someone tell me where this suitable .TXT file is saved? I don't find it.
  • Taylor Binnington 2/10/2014
    2270 Views
    Hi Metin,
    LEAP uses OSeMOSYS as an algorithm to perform its transformation module optimization calculations, but does not provide a facility for viewing other OSeMOSYS files graphically. This means that it is not possible to directly import Utopia.dat into LEAP.
    The text file that you're looking for (created by LEAP, for input into OSeMOSYS) is found in the area folder, which for Freedonia, you'll usually find in Documents\LEAP2011 Areas\Freedonia\. Look for files named opdata*.txt, where * is replaced by an integer that corresponds to each of the scenarios for which optimization is being conducted. Similarly, the opresults*.txt files are generated by OSeMOSYS, and are read back into LEAP. To know for sure which file corresponds to which scenario, you'll have to open them (the name of the scenario is included in the header of each).
    Incidentally, your questions are perfectly relevant here, but for specific OSeMOSYS-related questions, we maintain a (slightly less active) forum here, for such questions:
    http://www.energycommunity.org/default.asp?action=10&fid=104
    Hope this helps, and welcome to the forums!
  • Metin Caliskan 2/11/2014
    2264 Views
    Hello Taylor,
    Thanks for your precious help.
    I don't find the utopia file "optresults*.txt".
    Maybe I don't run the script correctly.
    For instance, I open Freedonia on LEAP.
    Then I just press on the button "results," after that I need to wait some second until to get the result.
    However, once I go to Documents\LEAP2011 Areas\Freedonia\. I find nothing.
    Do I proceed correctely???
    By the way, I perform an opdata search on all my PC, but I find nothing.
    That's what I get in my folder:
    Contents of folder: C:\Users\me\Documents\LEAP2011 Areas\freedonia2 11/02/2014 1:20 PM
    Date Time Attrib Bytes File name
    09/02/2014 11:22:16 PM A----- 20,480 $sql$functions.nx1
    09/02/2014 11:22:16 PM A----- 20,480 $sql$procedures.nx1
    09/02/2014 11:22:16 PM A----- 20,480 $sql$triggers.nx1
    09/02/2014 11:22:16 PM A----- 20,480 $sql$views.nx1
    11/02/2014 1:18:54 PM A----- 20,480 aggresultscache.nx1
    06/03/2011 10:50:44 AM A----- 68 area.ini
    11/02/2014 1:19:00 PM A----- 40,960 areadata.nx1
    11/02/2014 1:19:53 PM A----- 3,613 areasettings.ini
    28/07/2012 12:54:56 AM A----- 45,056 balcat.nx1
    28/07/2012 12:54:56 AM A----- 36,864 balcat2.nx1
    28/07/2012 12:54:56 AM A----- 36,864 balcat3.nx1
    28/07/2012 12:54:56 AM A----- 36,864 balcat4.nx1
    11/02/2014 1:11:42 PM A----- 585,728 batchtable.nx1
    28/07/2012 12:54:56 AM A----- 20,480 branchreferences.nx1
    28/07/2012 12:54:56 AM A----- 36,864 branchrefs.nx1
    28/07/2012 12:54:56 AM A----- 20,480 changelog.nx1
    28/07/2012 12:54:56 AM A----- 20,480 checksums.nx1
    28/07/2012 12:54:56 AM A----- 45,056 constants.nx1
    11/02/2014 1:18:57 PM A----- 147,456 deviceparents.nx1
    11/02/2014 1:18:54 PM A----- 20,480 diagnostics.nx1
    28/07/2012 12:54:56 AM A----- 20,480 effectrefs.nx1
    11/02/2014 1:18:57 PM A----- 5,001,216 envresults.nx1
    28/07/2012 12:54:56 AM A----- 36,864 fuelrefs.nx1
    11/02/2014 1:09:33 PM A----- 294,912 fuels.nx1
    28/07/2012 12:54:56 AM A----- 28,672 graphtable.nx1
    11/02/2014 1:18:47 PM A----- 98,304 gridtable.nx1
    28/07/2012 12:54:56 AM A----- 20,480 hiddenbranches.nx1
    04/02/2013 7:56:02 PM A----- 245,760 ipccgwpvalues.nx1
    28/07/2012 12:54:56 AM A----- 40,960 lifecycledata.nx1
    28/07/2012 12:54:56 AM A----- 32,768 lifecycletimedata.nx1
    11/02/2014 1:09:34 PM A----- 450,560 masterstructure.nx1
    11/02/2014 1:19:53 PM A----- 8 nxtrans.cfg
    27/07/2012 11:55:00 PM A----- 37 packedok.txt
    28/07/2012 12:54:56 AM A----- 1,351,680 refs.nx1
    28/07/2012 12:54:56 AM A----- 40,960 regioncategories.nx1
    28/07/2012 12:54:56 AM A----- 36,864 regioncategories2.nx1
    28/07/2012 12:54:56 AM A----- 36,864 regioncategories3.nx1
    28/07/2012 12:54:56 AM A----- 36,864 regioncategories4.nx1
    11/02/2014 1:18:57 PM A----- 57,344 regions.nx1
    11/02/2014 1:19:00 PM A----- 52,256 report.ini
    11/02/2014 1:18:57 PM A----- 2,297,856 results.nx1
    11/02/2014 1:18:47 PM A----- 122,880 scenariodata.nx1
    28/07/2012 12:55:00 AM A----- 45,056 scenarioinheritance.nx1
    11/02/2014 1:18:57 PM A----- 57,344 scenarios.nx1
    28/07/2012 12:55:00 AM A----- 49,152 scenariotemplate.nx1
    11/02/2014 1:11:24 PM A----- 79 SecureScripts.txt
    10/04/2013 3:11:40 PM A----- 147,456 staticdata.nx1
    28/07/2012 12:55:00 AM A----- 36,864 summaryreportrows.nx1
    28/07/2012 12:55:00 AM A----- 32,768 summaryreports.nx1
    11/02/2014 1:19:00 PM A----- 911 sysinfo.txt
    11/02/2014 1:09:33 PM A----- 495,616 tedeffects.nx1
    28/07/2012 12:55:00 AM A----- 294,912 tedenvdata.nx1
    28/07/2012 12:55:00 AM A----- 20,480 tedinputfuelsdata.nx1
    28/07/2012 12:55:00 AM A----- 20,480 tedoutputfuelsdata.nx1
    08/04/2013 6:34:08 PM A----- 1,036,288 tedtechdata.nx1
    28/07/2012 12:55:00 AM A----- 98,304 tedtechrefs.nx1
    28/07/2012 12:55:00 AM A----- 36,864 timeslicegroups.nx1
    11/02/2014 1:18:57 PM A----- 40,960 timesliceresults.nx1
    28/07/2012 12:55:00 AM A----- 61,440 timeslices.nx1
    28/07/2012 12:55:00 AM A----- 32,768 tsprofiledata.nx1
    28/07/2012 12:55:00 AM A----- 40,960 tsprofiles.nx1
    28/07/2012 12:55:00 AM A----- 36,864 unitclass.nx1
    28/07/2012 12:55:00 AM A----- 114,688 units.nx1
    08/04/2013 6:34:08 PM A----- 24,576 uservardata.nx1
    29/03/2013 1:24:34 PM A----- 49,152 variablecategories.nx1
    04/02/2013 7:56:04 PM A----- 28,672 variabledata.nx1
    28/07/2012 12:55:00 AM A----- 20,480 variableshortcuts.nx1
    09/02/2014 11:22:15 PM A----- 28,672 version.nx1
    11/02/2014 1:18:57 PM A----- 36,864 vintage.nx1
    28/07/2012 12:55:00 AM A----- 36,864 years.nx1
    14,429,836 70 Files
    Summary of C:\Users\me\Documents\LEAP2011 Areas\freedonia2
    Directories = 1
    Files = 70
    Bytes = 14,429,836
  • Taylor Binnington 2/11/2014
    2262 Views
    Hi Metin,
    Just to clarify - you will not find any Utopia file in LEAP's installation directories - this is a sample dataset that is provided for use with OSeMOSYS only, and is quite different from a LEAP area.
    You will only find opdata*.txt and opresults*.txt in area folders for which optimization has been enabled. So, you are generally looking in the correct place, but Freedonia (one of the basic training areas that is installed with LEAP) does not perform any optimization, hence you won't find any OSeMOSYS files in it.
    Try Exercise Six, detailed in our Training Materials here:
    http://www.energycommunity.org/default.asp?action=42
    This is also pre-installed with LEAP (the name of the area is 'Optimization Exercise') - open it up, calculate results, and then check the corresponding directory.
  • Metin Caliskan 2/12/2014
    2253 Views
    OK I understand now. Thank you so much for all your help.
    Metin
