• 286 views | 2 messages Discussion: LEAP
    Topic: Electricity import-export Subscribe | Previous | Next
  • Zviad Gachechiladze 2/26/2014
    1 Like 1914 Views
    Under yearly balance how to get the seasonality effect based on generation and demand load shapes? Currently, my LEAP model sets only export (net export i.e. if export is greater then import)or net import in yearly balance sheet, but doesn't show both at the same time.
  • Taylor Binnington 2/27/2014
    1902 Views
    Hi Zviad,
    Typically, energy balance sheets contain only annual figures, and in LEAP there is no way to display the Energy Balance view by time slice (assuming that you had set up your time slices to reflect seasonal variation).
    At this time, I don't have a way to work around this that I can suggest. LEAP calculates Exports and Imports only using an annual time step, so I'm afraid the only way to gain any insight into how each module is functioning within these slices is to use the results views that you'll find under Transformation: Actual Availability, Average Power Dispatched, or Average Power Requirements Not Dispatched.
