• 841 views | 6 messages Discussion: LEAP
    Topic: Yearly Shapes Subscribe | Previous | Next
  • Giorgi Pirveli 2/28/2014
    1992 Views
    What is the maximum number of yearly shapes that can be used in the current version of LEAP. So far I have 14 (Large HPPs, Commercial, transport, agriculture, food and beverages, other industry etc...)but last 4 yearly shapes are not working. Does it mean that maximum number of yearly shapes is 10? If this the case is it possible to increase shapes, or how can I solve this issue..
  • Taylor Binnington 2/28/2014
    1991 Views
    Hi Giorgi,
    This is a very interesting observation - thank you for pointing it out! As a further point of clarification, may I ask the number of time slices that you're using in your model? You'll find this at the bottom left corner of the window that appears after selecting General:Time Slices, from LEAP's main menu. We've found that the problem may be tied to the number of time slices.
    We've identified the issue that may be causing this problem. A new version of LEAP is due to be released shortly, and we'll be sure to incorporate this fix. In the meantime, I can propose a temporary workaround for you: have a look at LEAP's TimeSliceValue() function, here:
    http://www.energycommunity.org/WebHelpPro/Expressions/TimeSliceValue.htm
    For those yearly shapes beyond the 10th, that are not being recognized, try manually writing the values for each time slice into you expression like this:
    TimeSliceValue(Time Slice 1, 10, Time Slice 2, 20, etc...)
    Hope this holds you for a while,
  • Nikoloz Sumbadze 2/28/2014
    1989 Views
    Taylor,
    there are 12 time slices basically months.
    Also I have read somewhere in the discussions that maybe previous or current version of LEAP can use only 10 yearly shapes. (maybe i am wrong)
    I think if there will be possibility to use relatively more yearly shapes would be great, because for example we already have 14 (4 already is not working) and we also want use yearly shapes for household sector for different activities which might be additional 8-10.
    Thanks.
    Nikoloz
  • Charlie Heaps 2/28/2014
    1987 Views
    Hi all,
    I just want to follow up on what Taylor posted. I can confirm that there is a bug in the current version of LEAP (2012.056). This will be fixed in LEAP2014. A beta version of this will be available shortly (in a week or so) for testing purposes only. At that time there will be no particular limit on the number of yearly shapes you can define.
    Sorry for the inconvenience this is causing.
    1978 Views
    Hi Charles,
    I would like to give us your recommendation which version of LEAP to use (2012.056 or LEAP2014). while LEAP2014 version will only testing purposes it might need time to be finalized. however we would like to have preliminary results in a short time period.
    please tell us how to proceed.
    Nikoloz
    1976 Views
    The test version of 2014 should be available by late next week. This version will only being distributed to a few volunteers and for testing purposes only. The full version will be made public, I hope by mid March.
