• 2180 views | 9 messages Discussion: LEAP
    Topic: Optimization with CPLEX Subscribe | Previous | Next
  • Rahmat Al hasibi 6/27/2014
    1 Like 1907 Views
    I did optimization calculation for the area of optimization exercise with CPLEX feature in LEAP 2014. I found that LEAP stop working in very long time. CPLEX was installed correctly.
    Is there anything wrong in setting up CPLEX optimization?
    thank you very much
    rahmat
  • Taylor Binnington 6/27/2014
    1901 Views
    Hi Rahmat,
    That's great that you're trying to use the new CPLEX feature! Sorry you're seeing some problems, though.
    A few preliminary questions:
    1) Does your model calculate properly when you select "GLPK (Built-in, free)" from the Solver menu under basic Params:Optimization?
    2) To simplify debugging, is the button 'Enable Addition Size for Mixed Integer Linear Programming' unchecked? This may cause the optimization routine to run very slowly.
    3) What is the path that you have provided under the field 'CPLEX Solver Location'?
    Thanks very much,
  • Rahmat Al hasibi 6/30/2014
    1880 Views
    1. the model was ran ok when I selected GLPK solver.
    2. enable addition size for mixed integer was unchecked.
    3. C:\Program Files\IBM\ILOG\CPLEX_Studio126\opl\oplide\oplide.exe
    in the command windows, there are some explanation:
    1. model was successfully generated
    2. writing problem data to CPLEX3.lp
    thank you
    rahmat
  • Taylor Binnington 7/7/2014
    1878 Views
    Hi Rahmat,
    Thanks for the extra info. Please point the CPLEX Solver Location (in Basic Params) to this file, instead:
    C:\Program Files\IBM\ILOG\CPLEX_Studio126\cplex\bin\x64_win64\cplex.exe
    If you are still unable to successfully run your model, please post the contents of this file:
    Documents\LEAP2011 Areas\_Work\Area_1\cplex.log
    Thanks for your patience,
  • Rahmat Al hasibi 7/8/2014
    1874 Views
    It is very superb. The CPLEX optimization was run well with new path of the solver.
    Thank you very much.
    rahmat.
  • Jannik Haas 11/10/2014
    1581 Views
    I might have a similar problem.
    When I choose Cplex, the optimization finds the result (as I can read from the external window). The whole process takes about 5 minutes for a case that requires 5 times as long with the standart solver. However, after finishing (after the external windows closes) LEAP gets stuck.
    I already checked your first recommendations:
    1. The problem does run with the standard solver
    2. I have tried checking and unchecking the "enable addtional size from MIP...". However, it did not make any difference.
    3. CPLEX server location is as you posted:
    "C:\Program Files\IBM\ILOG\CPLEX_Studio125\cplex\bin\x64_win64\cplex.exe"
    Any clues?
    I noticed that at the end of the problem generation (before CPLEX solver is called), it says: "Writing problem data to CPLEX2.lp" (as shown on the image below). But then Cplex is called and (appearantly) solves the problem anyhow (cplex log can be found here: https://www.dropbox.com/s/sfmu6q4kdhekqpl/cplex.pdf?dl=0), followed the aformentioned crash of LEAP.
    Thanks for your help in advance.
    Cheers, Jannik
  • Charlie Heaps 11/17/2014
    1569 Views
    Please can you send me your data set as a .leap data file so I can look into this? Please send to leap@sei-us.org and mark for my attention.
  • Kamia Handayani 5/4/2017
    I have succesfully used CPLEX, both in my office PC and my personal laptop. However, recently I have problem running optimization feature in my PC. It runs, but when it finished running, there is nothing in the results. I only see the energy production of the base year. Nothing was appeared from the first year of simulation until the end year. So, I am now relying on my personal laptop to run the optimization feature. I have tried to un-install and re-install both LEAP and CPLEX in my PC. But so far those didnt solve the problem.
    My PC uses Microsoft Windows 7 Enterprise and Intel(R) Core(TM) i7-3770.
    Kamia
  • Taylor Binnington 5/9/2017
    Hi Kamia - sorry for the wait.
    Are you able to run your model without CPLEX? LEAP is pre-installed with the open-source GLPK solver, which you may default to if you wish. If you are still not able to generate the results you expect, then the problem may be with your model, rather than the solver.
    If you wish, you may also attach you model to this thread (or send the *.leap file directly to leap@sei-us.org) so that we can investigate it.
