• 266 views | 2 messages Discussion: LEAP
    Topic: I can not run LEAP Subscribe | Previous | Next
  • JUAN CARLOS MORENO DIAZ 7/7/2014
    1594 Views
    Hi, I have recently joined COMMEND community and I down the LEAP 2014.0.1.8. After installing it on my PC and run it I get an error on the window decimal separator is the same as the list separator character appears ". Change these separators, but is not activated softwared
    Run from my PC with Window 7 (64 bit) and in my note book with window 8. Both install as administrator but the error remains the same
  • Taylor Binnington 7/8/2014
    1591 Views
    Dear Juan,
    Depending on the Regional Settings of your computer, sometimes the list and decimal separators must be adjusted for LEAP to properly function.
    You can do this by selecting Control Panel: Clock, Language, and Region: Formats tab: Additional Settings. You can then change the decimal and list separator entries to ensure that they are different from one another (for example, select "." for the Decimal symbol and "," for the List separator). Once these settings are applied, please restart LEAP.
    Good luck,
