• 684 views | 4 messages Discussion: LEAP
    Topic: Calculation error: the calculated distribution loss is positive Subscribe | Previous | Next
  • Jingtong Hu 7/11/2014
    1649 Views
    I was using LEAP trying to build a energy balance sheet of China in 2011 using the energy balance sheet from IEA. However, no matter how I set the number of distribution loss rate, the calculation result is positive.
    Where did I do wrong?
  • Taylor Binnington 7/11/2014
    1648 Views
    Hi Jingtong,
    Please explain more clearly how you're implementing the distribution loss in LEAP. I'm also not sure what you mean when you say 'calculation result is positive'.
  • Jingtong Hu 7/20/2014
    1584 Views
    I mean in the energy balance sheet, the calculation results of loss is positive, which normally should be negative.
  • Taylor Binnington 7/30/2014
    1581 Views
    How is your distribution loss implemented in LEAP? Can you describe the module properties that you've set for your Distribution Loss transformation module? Please refer to this help page as a guide for which information to include:
    http://www.energycommunity.org/WebHelpPro/Transformation/Module_Properties_Wiziard.htm
    Thank you,
