• 260 views | 2 messages Discussion: LEAP
    Topic: type of fuel Subscribe | Previous | Next
  • Kong Felicity 7/31/2014
    1601 Views
    When I try to established the demand of household,I find some tpyes of fuel are not included in LEAP,for instance the coke oven gas.What should I do with this situation.Thanks in advance.
  • Taylor Binnington 7/31/2014
    1598 Views
    Hi Ella,
    LEAP contains only a default fuel database. But you can modify the properties of these fuels, or add your own customized or region-specific fuels.
    Click on the 'Fuels' icon in LEAP's toolbar. In the dialog box that appears, click the green '+' sign to add a new fuel, and specify it's state (solid, gas, etc...). You are then free to modify its properties by entering the appropriate values for the fuel, from within the Fuels database.
    Good luck,
