• 213 views | 2 messages Discussion: LEAP
    Topic: There is no base year in result Subscribe | Previous | Next
  • Li Kai 8/5/2014
    1573 Views
    Hi, Everyone!
    There is a problem when I running leap model. In the beginning, everything is ok! However, if I modify a parameter, there is no base year in the running result. I have checked the parameter, there is no problem! Can you help me?
    Good luck!
    KAI
  • Taylor Binnington 8/6/2014
    1571 Views
    Hi Kai,
    Try the following, and let me know if the problem persists.
    1) Close and re-open LEAP.
    2) Select Area: Force Whole Area to Recalculate.
    3) Click Results.
    Please also re-post your image, but without any special characters ("$", "{", etc.) in the filename.
