• 423 views | 3 messages Discussion: LEAP
    Topic: Results Calculator Freeze Subscribe | Previous | Next
  • Zanie Cilliers 8/6/2014
    1538 Views
    When I try to run results, the calculator freezes at 99% or 100%. All the results are shown in the background. I can even export the excel table of the results and click around in the tree to see results. Everything works, except for the fact that the calculator dialog box never disappears. I have to close LEAP and open it again to get rid of it.
    This problem does not occur if I run only one of my scenarios. It seems to occur when I run the Business as Usual (BAU) scenario along with any other scenario that draws from BAU as well as multiple other scenarios. If I run two scenarios that draw on BAU and multiple others, but do not run BAU itself, everything works fine.
  • Taylor Binnington 8/6/2014
    1537 Views
    Hi Zanie,
    Thank you for your description. To confirm: are you using the most up-to-date version of LEAP (currently 2014.0.1.14)?
    I'll need to see your model. Can you please email me your LEAP file directly (select Email from the main menu, or alternatively select Backup, and attach the resulting *.leap file to an email to leap@sei-us.org)?
    Thank you,
    1522 Views
    Hi Taylor
    Yes, I am using the most up-to-date version. I have sent the LEAP model as requested. Thanks for the quick response.
    Zanie
